Saltar al contenido principal
HP Pavilion DM3-3010US Keyboard Replacement
Qué necesitas
  1. HP Pavilion DM3-3010US Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop to bottom side and locate the battery eject switch.
  2. HP Pavilion DM3-3010US Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide switch inward, then pull the battery away from its slot.
    • Once free, place the battery to the side.
  3. HP Pavilion DM3-3010US Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Flip the laptop over and open it so the keyboard is visible.
    • Using a spudger, gently pry the keyboard away from the laptop using the three indicated markers.
    • Continue gently pulling the keyboard away from the laptop until it completely detaches.
  4. HP Pavilion DM3-3010US Keyboard Replacement: paso 4, imagen 1 de 2 HP Pavilion DM3-3010US Keyboard Replacement: paso 4, imagen 2 de 2
    • Once the keyboard is completely detached, locate the ribbon housing inside the laptop.
    • Gently pull the ribbon cable from the connector housing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,195
