Introducción
In this guide, you will learn how to replace your HP Pavilion 17-g119dx laptop's Wi-Fi card. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
Qué necesitas
Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
After running the Plastic Opening Tool along the sides, you can gently pop the keyboard open to access the Video Card.
The Video Card is located to the left of the fan and below the Processor.
Using the Phillips #00 screwdriver, remove one 0.5 mm screw.
Una persona más ha completado esta guía.
