Introducción
This guide will show you how to replace the random access memory card or RAM in your laptop. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
Qué necesitas
Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
After running the Plastic Opening Tool along the sides, you can gently lift the keyboard up and on top of the screen to access the RAM.
The RAM will be located above the Motherboard and next to the Processor.
3 personas más completaron esta guía.
