Saltar al contenido principal
HP Pavilion 17-g119dx Hard Drive Replacement
Qué necesitas
  1. HP Pavilion 17-g119dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx Hard Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion 17-g119dx Hard Drive Replacement: paso 2, imagen 2 de 2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx Hard Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion 17-g119dx Hard Drive Replacement: paso 3, imagen 2 de 2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx Hard Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion 17-g119dx Hard Drive Replacement: paso 4, imagen 2 de 2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx Hard Drive Replacement: paso 6, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 6, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 6, imagen 3 de 3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx Hard Drive Replacement: paso 7, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 7, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 7, imagen 3 de 3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx Hard Drive Replacement: paso 8, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 8, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 8, imagen 3 de 3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx Hard Drive Replacement: paso 9, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 9, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    Comprar
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx Hard Drive Replacement: paso 10, imagen 1 de 2 HP Pavilion 17-g119dx Hard Drive Replacement: paso 10, imagen 2 de 2
    • After running the opening tool along the sides, you can gently pop the keyboard open to access the Hard Drive.
    • The Hard Drive is located to the right of the RAM and above the Motherboard.
  11. HP Pavilion 17-g119dx Hard Drive Replacement: paso 11, imagen 1 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 11, imagen 2 de 3 HP Pavilion 17-g119dx Hard Drive Replacement: paso 11, imagen 3 de 3
    • To remove the Hard Drive, disconnect it from the cable by pulling out the base. Do not pull on the ribbon.
Conclusión
18 personas más completaron esta guía.
2 comentarios
Very helpful, thank you!
TCATDI - Contestar
Thnx indeed very helpful.
Willem Zweedyk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 11,306
