Saltar al contenido principal
HP Pavilion 17-f127ds Optical Drive Replacement
Qué necesitas
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: paso 2, imagen 1 de 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: paso 3, imagen 1 de 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Conclusión
Stephen Brown
Miembro Desde 10/18/17
201 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S3-G1, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Miembros
4 Guías creadas
Un comentario
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 932
