Saltar al contenido principal
HP Pavilion 17-f127ds Keyboard Replacement
Qué necesitas
  1. HP Pavilion 17-f127ds Keyboard Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion 17-f127ds Keyboard Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion 17-f127ds Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: paso 2, imagen 1 de 2 HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: paso 2, imagen 2 de 2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Keyboard Replacement: paso 3, imagen 1 de 3 HP Pavilion 17-f127ds Keyboard Replacement: paso 3, imagen 2 de 3 HP Pavilion 17-f127ds Keyboard Replacement: paso 3, imagen 3 de 3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
Conclusión
2 personas más completaron esta guía.
Alissa Tu
Miembro Desde 10/18/17
284 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S3-G1, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,140
