Saltar al contenido principal
HP Pavilion 17-f004dx Front Panel Replacement
Qué necesitas
  1. HP Pavilion 17-f004dx Front Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Front Panel Replacement: paso 2, imagen 1 de 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Front Panel Replacement, CD Drive: paso 3, imagen 1 de 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Front Panel Replacement: paso 4, imagen 1 de 3 HP Pavilion 17-f004dx Front Panel Replacement: paso 4, imagen 2 de 3 HP Pavilion 17-f004dx Front Panel Replacement: paso 4, imagen 3 de 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Front Panel Replacement, Front Panel: paso 5, imagen 1 de 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Front Panel Replacement: paso 6, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 6, imagen 2 de 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Front Panel Replacement: paso 7, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 7, imagen 2 de 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Front Panel Replacement: paso 8, imagen 1 de 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Front Panel Replacement: paso 9, imagen 1 de 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Front Panel Replacement: paso 10, imagen 1 de 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Front Panel Replacement: paso 11, imagen 1 de 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Front Panel Replacement: paso 12, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 12, imagen 2 de 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Front Panel Replacement: paso 13, imagen 1 de 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Front Panel Replacement: paso 14, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 14, imagen 2 de 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Front Panel Replacement: paso 15, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 15, imagen 2 de 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Front Panel Replacement: paso 16, imagen 1 de 2 HP Pavilion 17-f004dx Front Panel Replacement: paso 16, imagen 2 de 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
Conclusión
Una persona más ha completado esta guía.
Allan Soria
Miembro Desde 09/21/16
623 Reputación
4 Guías creadas
Equipo
UC Davis, Team 1-4, Oliver Fall 2016 Miembro de UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Miembros
8 Guías creadas
Un comentario
I need the fan , how much?
محمد السيد - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,290
