Saltar al contenido principal
HP Pavilion 17 TS RAM Replacement
Qué necesitas
  1. HP Pavilion 17 TS RAM Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion 17 TS RAM Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion 17 TS RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS RAM Replacement, Rear Cover: paso 2, imagen 1 de 3 HP Pavilion 17 TS RAM Replacement, Rear Cover: paso 2, imagen 2 de 3 HP Pavilion 17 TS RAM Replacement, Rear Cover: paso 2, imagen 3 de 3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS RAM Replacement, RAM: paso 3, imagen 1 de 3 HP Pavilion 17 TS RAM Replacement, RAM: paso 3, imagen 2 de 3 HP Pavilion 17 TS RAM Replacement, RAM: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • On each side of each RAM card, there will be a thin strip of metal that is holding the chip down. Using tweezers or another thin tool, gently push these pins apart.
    • The first RAM card should pop up on its own. Gently remove this card, and look for the two strips of metal holding the bottom card down.
    • Push the pins apart just like for card one. Just like the first card, this one will pop up and you can remove it.
Conclusión
Eric Sowersby
Miembro Desde 03/25/16
413 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 674
