Saltar al contenido principal
HP Pavilion 17 TS Disk Drive Replacement
Qué necesitas
  1. HP Pavilion 17 TS Disk Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion 17 TS Disk Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion 17 TS Disk Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: paso 2, imagen 1 de 3 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: paso 2, imagen 2 de 3 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: paso 2, imagen 3 de 3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: paso 3, imagen 1 de 3 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: paso 3, imagen 2 de 3 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: paso 3, imagen 3 de 3
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
Conclusión
Eric Sowersby
Miembro Desde 03/25/16
413 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-6, Miles Spring 2016 Miembro de UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
Miembros de 3
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 549
