Saltar al contenido principal
HP Pavilion 15-p214dx Battery Replacement
Qué necesitas
  1. HP Pavilion 15-p214dx Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-p214dx Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
  2. HP Pavilion 15-p214dx Battery Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-p214dx Battery Replacement: paso 2, imagen 2 de 2
    • Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
    • While holding the latch in place, remove the battery from the laptop's battery bay.
    • When inserting a battery into the battery bay, the battery release latch does not need to be held open.
Conclusión
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
Patrick Seaver
Miembro Desde 03/25/19
1,001 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 564
