Introducción
If your laptop is having disc-reading errors or if the sound or video is degraded when using the CD Or DVD disc, use this guide if you need to replace your optical drive. For this guide you will need a #1 Phillips screwdriver. We will be unscrewing a screw size of 8 mm. This replacement is simple and doesn't require extensive knowledge.
Qué necesitas
Casi Terminas!
Conclusión
