Saltar al contenido principal
HP Pavilion 15-p043cl Repair Optical Drive Replacement
Qué necesitas
  1. HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement, Optical Drive: paso 1, imagen 2 de 2
    • Flip over the laptop so that the screws on the bottom are exposed.
  2. HP Pavilion 15-p043cl Repair Optical Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-p043cl Repair Optical Drive Replacement: paso 2, imagen 2 de 2
    • Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
    • There is a CD/DVD symbol on the case that helps identify the correct screw.
  3. HP Pavilion 15-p043cl Repair Optical Drive Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-p043cl Repair Optical Drive Replacement: paso 3, imagen 3 de 3
    • Use your fingers or a wedge to pull out the Optical Drive from it's slot.
    • If the faceplate of the drive is pulled off it can be reattached.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 57
