Saltar al contenido principal
HP Pavilion 15-p043cl Repair I/O Replacement
Qué necesitas
  1. HP Pavilion 15-p043cl Repair I/O Replacement, I/O: paso 1, imagen 1 de 2 HP Pavilion 15-p043cl Repair I/O Replacement, I/O: paso 1, imagen 2 de 2
    • Flip the laptop over, showing the backplate face up
  2. HP Pavilion 15-p043cl Repair I/O Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 2, imagen 3 de 3
    • Use your #1 Phillips-head screwdriver to remove all the 8 mm screws
    • Make sure to put the screws in a magnetic holder or another safe place
  3. HP Pavilion 15-p043cl Repair I/O Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 3, imagen 3 de 3
    • After removing all the 8 mm screws, start to pry open the optical drive using your finders or a wedge.
  4. HP Pavilion 15-p043cl Repair I/O Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-p043cl Repair I/O Replacement: paso 4, imagen 2 de 2
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop.
  5. HP Pavilion 15-p043cl Repair I/O Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 5, imagen 3 de 3
    • Use an opening pick or wedge to start to pry open the laptop keyboard cover.
    • Follow along the perimeter and separate the cover from the laptop.
  6. HP Pavilion 15-p043cl Repair I/O Replacement: paso 6, imagen 1 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 6, imagen 2 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 6, imagen 3 de 3
    • Carefully remove the keyboard assembly.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard, mousepad and power button to the motherboard
  7. HP Pavilion 15-p043cl Repair I/O Replacement: paso 7, imagen 1 de 2 HP Pavilion 15-p043cl Repair I/O Replacement: paso 7, imagen 2 de 2
    • Locate the I/O ports, and remove the bottom most ribbon cable.
  8. HP Pavilion 15-p043cl Repair I/O Replacement: paso 8, imagen 1 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 8, imagen 2 de 3 HP Pavilion 15-p043cl Repair I/O Replacement: paso 8, imagen 3 de 3
    • Locate and remove the screw holding the I/O board in.
    • Once the screw has been removed lift the I/O board straight up and out of the case.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 95
