Saltar al contenido principal
HP Pavilion 15-n232nr Hard Drive Replacement
Qué necesitas
  1. HP Pavilion 15-n232nr Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 2, imagen 3 de 3
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: paso 3, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Keyboard: paso 3, imagen 2 de 2
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  4. HP Pavilion 15-n232nr Hard Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: paso 4, imagen 2 de 2
    • Flip the laptop to the front side and open it up.
  5. HP Pavilion 15-n232nr Hard Drive Replacement: paso 5, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: paso 5, imagen 2 de 2
    • Use the metal spudger to release the keyboard from the front panel.
  6. HP Pavilion 15-n232nr Hard Drive Replacement: paso 6, imagen 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 6, imagen 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 6, imagen 3 de 3
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  7. HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: paso 7, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Optical Drive: paso 7, imagen 2 de 2
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  8. HP Pavilion 15-n232nr Hard Drive Replacement: paso 8, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: paso 8, imagen 2 de 2
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  9. HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: paso 9, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement, Hard Drive: paso 9, imagen 2 de 2
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  10. HP Pavilion 15-n232nr Hard Drive Replacement: paso 10, imagen 1 de 2 HP Pavilion 15-n232nr Hard Drive Replacement: paso 10, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  11. HP Pavilion 15-n232nr Hard Drive Replacement: paso 11, imagen 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 11, imagen 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 11, imagen 3 de 3
    • Carefully use the iFixit opening tool to release the front panel.
  12. HP Pavilion 15-n232nr Hard Drive Replacement: paso 12, imagen 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 12, imagen 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 12, imagen 3 de 3
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  13. HP Pavilion 15-n232nr Hard Drive Replacement: paso 13, imagen 1 de 1
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  14. HP Pavilion 15-n232nr Hard Drive Replacement: paso 14, imagen 1 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 14, imagen 2 de 3 HP Pavilion 15-n232nr Hard Drive Replacement: paso 14, imagen 3 de 3
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
Conclusión
6 personas más completaron esta guía.
2 comentarios
How to test it's processor
Kashmir Singh - Contestar
Great guide, thank you!!
alt255d - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,377
