Saltar al contenido principal
HP Pavilion 15-n232nr Cooling Fan Replacement
Qué necesitas
  1. HP Pavilion 15-n232nr Cooling Fan Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over.
  2. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 2, imagen 3 de 3
    • Slide the battery locks towards the center of the laptop. The battery will detach automatically.
    • Remove the battery by sliding it away from the laptop housing.
  3. HP Pavilion 15-n232nr Cooling Fan Replacement, Optical Drive: paso 3, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement, Optical Drive: paso 3, imagen 2 de 2
    • Remove the 6 mm Phillips #1 screw securing the optical drive.
  4. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Use the iFixit opening tool to slide the optical drive away from the laptop housing.
  5. HP Pavilion 15-n232nr Cooling Fan Replacement, Keyboard: paso 5, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement, Keyboard: paso 5, imagen 2 de 2
    • Unscrew the 6 mm Phillips #1 screw securing the keyboard.
  6. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Flip the laptop to the front side and open it up.
  7. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 7, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 7, imagen 2 de 2
    • Use the metal spudger to release the keyboard from the front panel.
  8. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 8, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 8, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 8, imagen 3 de 3
    • Flip the keyboard out and locate the connector.
    • Use the spudger to unhinge the the fastener and remove the connector.
    • Keyboard should be completely detached after this step.
  9. HP Pavilion 15-n232nr Cooling Fan Replacement, RAM: paso 9, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement, RAM: paso 9, imagen 2 de 2
    • Loosen the two 6 mm Phillips #1 screws on the back panel.
    • These screws do not detach from back panel.
  10. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 10, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 10, imagen 2 de 2
    • Use the iFixit opening tool to remove the back panel.
  11. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 11, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 11, imagen 2 de 2
    • Release the clips securing the RAM by slightly bending them until the RAM is free.
  12. HP Pavilion 15-n232nr Cooling Fan Replacement, Hard Drive: paso 12, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement, Hard Drive: paso 12, imagen 2 de 2
    • The battery and optical drive should be removed at this point in the process.
    • Remove the ten 6 mm Phillips #1 screws.
    • Remove the three 1 mm Phillips #000 screws.
  13. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 13, imagen 1 de 2 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 13, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the five 2.5mm Phillips #1 screws.
    • Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
  14. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 14, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 14, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 14, imagen 3 de 3
    • Carefully use the iFixit opening tool to release the front panel.
  15. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 15, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 15, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 15, imagen 3 de 3
    • Use the spudger to unhinge the daughterboard connector.
    • Remove daughterboard connector.
  16. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 16, imagen 1 de 1
    • Remove the 2.5 mm Phillips #1 screw and remove the daughterboard
  17. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 17, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 17, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 17, imagen 3 de 3
    • Use the iFixit opening tool to remove the hard drive connector.
    • Remove the hard drive by lifting the right side and pulling it out.
  18. HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: paso 18, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: paso 18, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement, Cooling Fan: paso 18, imagen 3 de 3
    • Remove the four 6 mm Phillips #1 screws.
    • Turn over the laptop to have easier access to the cooling fan.
  19. HP Pavilion 15-n232nr Cooling Fan Replacement: paso 19, imagen 1 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 19, imagen 2 de 3 HP Pavilion 15-n232nr Cooling Fan Replacement: paso 19, imagen 3 de 3
    • Unscrew the two 4 mm Phillips #1 screws.
    • Disconnect the cord for the cooling fan.
    • Carefully lift the cooling fan from the motherboard.
Conclusión
Una persona más ha completado esta guía.
[deleted]
Miembro Desde 03/18/19
283 Reputación
2 Guías creadas
Un comentario
Sehr gute Anleitung, Dank an Andrei Fendly
H. Hofmann
Helmut Hofmann - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 725
