Introducción
This guide will walk through the steps to replace the Motherboard of the HP Pavilion 15-d017cl. The Motherboard allows communication and power throughout the computer through accessing memory and CPU. This guide requires a Phillips #1 screwdriver, spudger, tweezers, and an iFixit opening tool.
Qué necesitas
To unlock the top left latch, place your finger on the black latch and slide toward the center of the computer.
Flip the laptop onto its back in order to have access to the back panel.
Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
Detach the connected chord with your fingers from the motherboard.
Remove the fifteen (15) 5mm screws using the Phillips #1 Screwdriver from the case.
4 personas más completaron esta guía.
