Saltar al contenido principal
HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement
Qué necesitas
  1. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Flip it over: paso 1, imagen 1 de 1
    • First thing you'll do is flip it over, remove any SD cards, USBs, and remove any case.
  2. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: paso 2, imagen 1 de 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: paso 2, imagen 2 de 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Remove screws: paso 2, imagen 3 de 3
    • There will be about 6 screws you'll need to remove.
    • You will have to at least partially remove the rubber feet to access 3 of the screws.
    • The screws are really tiny, so I recommend putting them in a Tupperware or Ziploc if you don't have a magnetic screw tray.
  3. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Credit Card or Pry Tool: paso 3, imagen 1 de 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Credit Card or Pry Tool: paso 3, imagen 2 de 2
    • You'll use a credit card, ID card, or pry tool to separate the bottom of the laptop from the rest of it. Make sure it's plastic, not metal.
    • You might want to use multiple to hold sections open as you work your way around.
  4. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Pop That Sucker Off: paso 4, imagen 1 de 1
    • You remove the bottom to reveal the guts.
  5. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Where's Waldo?: paso 5, imagen 1 de 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Where's Waldo?: paso 5, imagen 2 de 2
    • Find the WiFi module.
  6. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unplugging: paso 6, imagen 1 de 1
    • Detach the antenna cables.
  7. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unscrew the Module: paso 7, imagen 1 de 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Unscrew the Module: paso 7, imagen 2 de 2
    • Unscrew the screw.
    • It will pop up once it's unscrewed. That's normal.
  8. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Yoink: paso 8, imagen 1 de 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Yoink: paso 8, imagen 2 de 2
    • Pull the module out.
  9. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Put in the New Module: paso 9, imagen 1 de 1
    • Put in the new module.
    • You might need to push the end to get it to seat.
  10. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Screw it in: paso 10, imagen 1 de 2 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Screw it in: paso 10, imagen 2 de 2
    • Push it flat and screw it in.
  11. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: paso 11, imagen 1 de 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: paso 11, imagen 2 de 3 HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Reattach Cables: paso 11, imagen 3 de 3
    • Reattach the antenna cables.
    • They should have labels "1" and "2" on the cables. Attach them to the points labeled "1" and "2" on your new WiFi module.
    • They're teeny-tiny snap buttons, like miniature versions of what you'd find on a jacket.
    • Make sure they snap on properly, you might need to use your thumbnail. You can give them a gentle tug to make sure they're actually attached.
  12. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Close it up!: paso 12, imagen 1 de 1
    • Snap the lid back on
    • Put the lid screws back in
    • Stick the sticky rubber feetsies back on
    • Plug back in any SD cards, USBs, and put your case back on if you have one
  13. HP Pavilion 15-cs3065cl WiFi Module Upgrade/Replacement, Drivers (Software): paso 13, imagen 1 de 1
    • Go to this link and install the WiFi and Bluetooth drivers that Intel recommends.
    • Power cycle your laptop (off and on again).
    • That's it, you're good to go!
Conclusión
You're all set!
Quinn Enestvedt
Miembro Desde 09/05/25
493 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 31
