Saltar al contenido principal
HP Pavilion 15-cc023cl Battery Replacement
Qué necesitas
  1. HP Pavilion 15-cc023cl Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-cc023cl Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Battery Replacement: paso 2, imagen 1 de 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-cc023cl Battery Replacement: paso 3, imagen 2 de 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Battery Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-cc023cl Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
Conclusión
7 personas más completaron esta guía.
2 comentarios
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - Contestar
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
Don't hurt the chickens -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 53
Todo El Tiempo: 3,769
