Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Make sure the power cord is not plugged in and that the device is powered completely off before you begin. Before making any hardware changes to this laptop, make sure the battery is completely removed. This will make repair safer for both you and your laptop.
  1. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel. Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery. Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  5. Disconnect the port connecting the battery and the motherboard and then remove. Disconnect the port connecting the battery and the motherboard and then remove.
    • Disconnect the port connecting the battery and the motherboard and then remove.
Conclusión
5 personas más completaron esta guía.
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 71
Todo El Tiempo: 1,482
