Saltar al contenido principal
HP Pavilion 15-bk020wm Touchscreen Replacement
Qué necesitas
  1. HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: paso 1, imagen 1 de 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Keyboard Cover: paso 1, imagen 2 de 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-bk020wm Touchscreen Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-bk020wm Touchscreen Replacement: paso 2, imagen 3 de 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 3, imagen 1 de 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: paso 4, imagen 1 de 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Battery: paso 4, imagen 2 de 2
    • Detach the blue ZIF cable from the bottom of the laptop.
    • Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
  5. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 5, imagen 1 de 1
    • Remove the four Phillips M2.5x4.4 screws using the Phillips 00 located along the perimeter of the battery.
  6. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 6, imagen 1 de 1
    • Lift the damaged battery from the laptop.
    • Insert the new battery.
  7. HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: paso 7, imagen 1 de 2 HP Pavilion 15-bk020wm Touchscreen Replacement, Touchscreen: paso 7, imagen 2 de 2
    • Detach the two cables from the motherboard.
  8. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 8, imagen 1 de 1
    • Unscrew all ten screws (M2.5x4.4) using the Phillips 00 screwdriver from the motherboard. Be sure to unscrew the fan as well.
    • Lift the motherboard with the fan.
  9. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 9, imagen 1 de 2 HP Pavilion 15-bk020wm Touchscreen Replacement: paso 9, imagen 2 de 2
    • Unscrew the screen from the laptop body using Phillips 00. Screw size: M2.5x4.4
  10. HP Pavilion 15-bk020wm Touchscreen Replacement: paso 10, imagen 1 de 1
    • Lift the touchscreen hinges using the plastic opening tool to detach the screen.
    • Obtain the new touchscreen to connect to your device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 5,708
