Saltar al contenido principal
HP Pavilion 15-bk020wm Hard Drive Replacement
Qué necesitas
  1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: paso 1, imagen 1 de 2 HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: paso 1, imagen 2 de 2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Hard Drive Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-bk020wm Hard Drive Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-bk020wm Hard Drive Replacement: paso 2, imagen 3 de 3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Hard Drive Replacement: paso 3, imagen 1 de 1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the hard drive from the laptop.
    • Our device did not contain a hard drive.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 49
Todo El Tiempo: 17,359
