Saltar al contenido principal
HP Pavilion 15-ba003ds Screen Replacement
Qué necesitas
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: paso 1, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: paso 1, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 2, imagen 3 de 3
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 3, imagen 3 de 3
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: paso 4, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 4, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 4, imagen 3 de 3
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 5, imagen 3 de 3
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: paso 6, imagen 1 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 6, imagen 2 de 3 HP Pavilion 15-ba003ds Screen Replacement: paso 6, imagen 3 de 3
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: paso 7, imagen 1 de 1
    • Lift the screen away from the laptop.
Conclusión
Joseph Chia
Miembro Desde 01/14/20
355 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 252
