Saltar al contenido principal
HP Pavilion 15-ba003ds RAM Replacement
Qué necesitas
  1. HP Pavilion 15-ba003ds RAM Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-ba003ds RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: paso 2, imagen 1 de 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds RAM Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-ba003ds RAM Replacement: paso 3, imagen 2 de 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds RAM Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-ba003ds RAM Replacement: paso 4, imagen 2 de 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds RAM Replacement, Backplate: paso 5, imagen 1 de 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: paso 5, imagen 2 de 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: paso 5, imagen 3 de 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: paso 6, imagen 1 de 2 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: paso 6, imagen 2 de 2
    • To release the RAM, hold and pull the strips outwards on either side of the RAM.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 277
