Saltar al contenido principal
HP Pavilion 15-ba003ds Charging Port Replacement
Qué necesitas
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: paso 2, imagen 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: paso 2, imagen 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: paso 2, imagen 3 de 3
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: paso 3, imagen 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: paso 3, imagen 2 de 2
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: paso 4, imagen 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 4, imagen 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 4, imagen 3 de 3
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 5, imagen 3 de 3
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: paso 6, imagen 1 de 1
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: paso 7, imagen 1 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 7, imagen 2 de 3 HP Pavilion 15-ba003ds Charging Port Replacement: paso 7, imagen 3 de 3
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: paso 8, imagen 1 de 2 HP Pavilion 15-ba003ds Charging Port Replacement: paso 8, imagen 2 de 2
    • Use a spudger to pry off the charging port.
Conclusión
LI XU
Miembro Desde 01/14/20
334 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 54
Todo El Tiempo: 2,155
