Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will show you how to replace your Memory Module in your HP Pavilion 15-b109wm. This process will take about 1 hour, and is very tedious. So take your time, complete each task carefully, and you'll have a successful replacement of your Memory Module.
  1. Power off the device and disconnect from any power source.
    • Power off the device and disconnect from any power source.
  2. Turn the device upside down and ensure the back of the device is facing you.
    • Turn the device upside down and ensure the back of the device is facing you.
  3. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out.
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot.
    • Pull out the battery from the device's battery slot.
  5. Use JIS #1 screwdriver to remove the eleven 6 mm screws. Use JIS #1 screwdriver to remove the eleven 6 mm screws.
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. Locate the two screw holes that allow access to removing the keyboard.
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. Turn the device onto its side.
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  9. Using a plastic opening tool, release the keyboard clips. Using a plastic opening tool, release the keyboard clips.
    • Using a plastic opening tool, release the keyboard clips.
  10. Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  11. Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector. To detach the connector, release by lifting the black plastic tab up. To detach the connector, release by lifting the black plastic tab up.
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  12. Using a JIS #1 screwdriver, remove the five 5mm screws. Detach the power button cable. Detach the touch pad cable.
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  13. Using a plastic opening tool, pry open the top cover. Unscrew the two 5 mm screws using a JIS #1 screwdriver. Gently, pull to detach the fan cable.
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  14. Carefully remove the fan from its slot.
    • Carefully remove the fan from its slot.
  15. Disconnect the cables to the motherboard. Disconnect the cables to the motherboard. Disconnect the cables to the motherboard.
    • Disconnect the cables to the motherboard.
  16. Remove the eight 5 mm screws with the JIS #1 screwdriver. Remove the eight 5 mm screws with the JIS #1 screwdriver.
    • Remove the eight 5 mm screws with the JIS #1 screwdriver.
  17. Remove the hard drive. Remove the hard drive.
    • Remove the hard drive.
  18. Unclip the WLAN cable out of its place to allow the motherboard room to move.
    • Unclip the WLAN cable out of its place to allow the motherboard room to move.
  19. Detach the power connector cable.
    • Detach the power connector cable.
  20. Lift up the motherboard from the bottom side of the device. Lift up the motherboard from the bottom side of the device.
    • Lift up the motherboard from the bottom side of the device.
  21. Using your thumbs, push out on the bracket. When the memory module feels loose, pull up on the module. When the memory module feels loose, pull up on the module.
    • Using your thumbs, push out on the bracket.
    • When the memory module feels loose, pull up on the module.
Conclusión
Stephen Gacioch
Miembro Desde 26/10/18
437 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 285
