Saltar al contenido principal
HP Pavilion 15-b109wm Fan Replacement
Qué necesitas
  1. HP Pavilion 15-b109wm Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Fan Replacement: paso 2, imagen 1 de 1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Fan Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 3, imagen 3 de 3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Fan Replacement: paso 4, imagen 1 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 4, imagen 2 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 4, imagen 3 de 3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Fan Replacement, Keyboard: paso 5, imagen 1 de 2 HP Pavilion 15-b109wm Fan Replacement, Keyboard: paso 5, imagen 2 de 2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Fan Replacement: paso 6, imagen 1 de 1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Fan Replacement: paso 7, imagen 1 de 1
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Fan Replacement: paso 8, imagen 1 de 2 HP Pavilion 15-b109wm Fan Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Fan Replacement: paso 9, imagen 1 de 1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Fan Replacement: paso 10, imagen 1 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 10, imagen 2 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 10, imagen 3 de 3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm Fan Replacement, Fan: paso 11, imagen 1 de 3 HP Pavilion 15-b109wm Fan Replacement, Fan: paso 11, imagen 2 de 3 HP Pavilion 15-b109wm Fan Replacement, Fan: paso 11, imagen 3 de 3
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm Fan Replacement: paso 12, imagen 1 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 12, imagen 2 de 3 HP Pavilion 15-b109wm Fan Replacement: paso 12, imagen 3 de 3
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm Fan Replacement: paso 13, imagen 1 de 1
    • Carefully remove the fan from its slot.
Conclusión
Stephen Gacioch
Miembro Desde 10/26/18
437 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 397
