Saltar al contenido principal
HP Pavilion 15-ay041wm RAM Replacement
Qué necesitas
  1. HP Pavilion 15-ay041wm RAM Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion 15-ay041wm RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-ay041wm RAM Replacement: paso 2, imagen 2 de 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-ay041wm RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-ay041wm RAM Replacement: paso 3, imagen 3 de 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm RAM Replacement, Disc Drive: paso 4, imagen 1 de 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm RAM Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-ay041wm RAM Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-ay041wm RAM Replacement: paso 5, imagen 3 de 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm RAM Replacement, Keyboard: paso 6, imagen 1 de 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: paso 6, imagen 2 de 3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: paso 6, imagen 3 de 3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavilion 15-ay041wm RAM Replacement, RAM: paso 7, imagen 1 de 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: paso 7, imagen 2 de 3 HP Pavilion 15-ay041wm RAM Replacement, RAM: paso 7, imagen 3 de 3
    • Orient the base of the laptop with the base facing away from you.
    • With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
    • Simultaneously, use your index finger to push the RAM sticks towards you.
    • The RAM stick will release and pop up and out.
  8. HP Pavilion 15-ay041wm RAM Replacement: paso 8, imagen 1 de 2 HP Pavilion 15-ay041wm RAM Replacement: paso 8, imagen 2 de 2
    • Repeat the same process for the top RAM stick.
    • The RAM stick will release and pop up. Pull the RAM stick out to remove it from the laptop.
Conclusión
Carlton Makini
Miembro Desde 01/30/20
195 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 45
Todo El Tiempo: 991
