Saltar al contenido principal
HP Pavilion 15-au123cl RAM Replacement
Qué necesitas
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-au123cl RAM Replacement: paso 2, imagen 2 de 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl RAM Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-au123cl RAM Replacement: paso 3, imagen 2 de 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl RAM Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-au123cl RAM Replacement: paso 4, imagen 2 de 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl RAM Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-au123cl RAM Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-au123cl RAM Replacement: paso 5, imagen 3 de 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: paso 6, imagen 1 de 2 HP Pavilion 15-au123cl RAM Replacement, RAM: paso 6, imagen 2 de 2
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: paso 7, imagen 1 de 1
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
Conclusión
2 personas más completaron esta guía.
Mohammad Gardezi
Miembro Desde 10/17/17
1,420 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S13-G3, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Miembros
6 Guías creadas
Un comentario
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 1,274
