Introducción
If you have noticed that your computer is no longer booting up and you have come to the conclusion that the hard drive is the problem, this guide will walk you through the sets to replace the hard drive. You will first remove the battery and then the hard drive. Using the tools suggested, you should have no problem removing the hard drive.
Qué necesitas
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
The hard drive is located at the lower left area of the motherboard.
Using the spudger, lift the white latch holding the hard drive cable in place.
10 personas más completaron esta guía.
Un comentario
The latch on mine was black, and the socket on the m/b was white. Guess who ruined his m/b following these instructions?
