Saltar al contenido principal
HP Pavilion 15-au123cl Fan Replacement
Qué necesitas
  1. HP Pavilion 15-au123cl Fan Replacement, Fan: paso 1, imagen 1 de 2 HP Pavilion 15-au123cl Fan Replacement, Fan: paso 1, imagen 2 de 2
    • Remove the ten screws from the back case with a Phillips #0 screwdriver.
    • Using a plastic opening tool, pry the CD drive from the computer.
    • Remove the back panel from the computer.
  2. HP Pavilion 15-au123cl Fan Replacement: paso 2, imagen 1 de 1
    • Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
    • Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
    • Gently disconnect the fan cable cable.
    • Remove the fan.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 498
