Saltar al contenido principal
HP Pavilion 15-au123cl CD Drive Replacement
Qué necesitas
  1. HP Pavilion 15-au123cl CD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl CD Drive Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: paso 2, imagen 2 de 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl CD Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: paso 3, imagen 2 de 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl CD Drive Replacement: paso 4, imagen 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: paso 4, imagen 2 de 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl CD Drive Replacement: paso 5, imagen 1 de 3 HP Pavilion 15-au123cl CD Drive Replacement: paso 5, imagen 2 de 3 HP Pavilion 15-au123cl CD Drive Replacement: paso 5, imagen 3 de 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl CD Drive Replacement, CD Drive: paso 6, imagen 1 de 1
    • The CD Drive is located at the bottom right area of the motherboard.
  7. HP Pavilion 15-au123cl CD Drive Replacement: paso 7, imagen 1 de 2 HP Pavilion 15-au123cl CD Drive Replacement: paso 7, imagen 2 de 2
    • Disconnect the CD drive from the motherboard connector on the left.
Conclusión
Mohammad Gardezi
Miembro Desde 10/17/17
1,420 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S13-G3, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 548
