Introducción
This guide will show you how to open your device and remove the hard drive. Whether you have a failed hard drive or simply want to upgrade to more capacity this guide will take you through the necessary steps involved in replacement.
Qué necesitas
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
3 personas más completaron esta guía.
