Introducción
The CMOS Battery is responsible for keeping your time clock correct on the device, even after the main battery runs out of juice. If you are experiencing issues with your time clock resetting, then this guide will help you replace the battery.
Qué necesitas
Slide the battery lock tab toward the center of the battery to the unlock position.
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
Use long nose tweezers to reach under battery and lift up.
Una persona más ha completado esta guía.
