Introducción
This is a simple and straight forward procedure to replace the CD-Drive on your device. If your CD-drive has failed and will no longer read discs, then following this guide will help you regain a functioning drive.
Qué necesitas
Locate the screw, will have a CD symbol next to it, and remove this 3.5 mm screw with a PH0 screw driver.
Una persona más ha completado esta guía.
