Saltar al contenido principal
HP Pavilion 15-ab165us RAM Replacement
Qué necesitas
  1. HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: paso 1, imagen 1 de 2 HP Pavilion 15-ab165us RAM Replacement, Battery and Back Cover: paso 1, imagen 2 de 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us RAM Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-ab165us RAM Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-ab165us RAM Replacement: paso 2, imagen 3 de 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us RAM Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-ab165us RAM Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-ab165us RAM Replacement: paso 3, imagen 3 de 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us RAM Replacement: paso 4, imagen 1 de 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us RAM Replacement: paso 5, imagen 1 de 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us RAM Replacement: paso 6, imagen 1 de 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us RAM Replacement: paso 7, imagen 1 de 2 HP Pavilion 15-ab165us RAM Replacement: paso 7, imagen 2 de 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us RAM Replacement: paso 8, imagen 1 de 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us RAM Replacement, RAM: paso 9, imagen 1 de 1
    • Locate RAM.
  10. HP Pavilion 15-ab165us RAM Replacement: paso 10, imagen 1 de 1
    • Pull the tension arms away from both sides the RAM.
  11. HP Pavilion 15-ab165us RAM Replacement: paso 11, imagen 1 de 1
    • Pull RAM away from the RAM slot.
  12. HP Pavilion 15-ab165us RAM Replacement: paso 12, imagen 1 de 1
    • Repeat this process for the next stick of RAM.
Conclusión
3 personas más completaron esta guía.
Myai Nguyen
Miembro Desde 10/20/17
203 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G2, Rose Fall 2017 Miembro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
Miembros de 5
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 2,386
