Saltar al contenido principal
HP Pavilion 15-ab165us Motherboard Replacement
Qué necesitas
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: paso 1, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: paso 1, imagen 2 de 2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: paso 2, imagen 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 2, imagen 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: paso 3, imagen 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 3, imagen 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: paso 5, imagen 1 de 1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: paso 7, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 7, imagen 2 de 2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: paso 8, imagen 1 de 1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: paso 10, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 10, imagen 2 de 2
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: paso 11, imagen 1 de 1
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: paso 12, imagen 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 12, imagen 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 12, imagen 3 de 3
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: paso 13, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 13, imagen 2 de 2
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: paso 14, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 14, imagen 2 de 2
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: paso 15, imagen 1 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 15, imagen 2 de 3 HP Pavilion 15-ab165us Motherboard Replacement: paso 15, imagen 3 de 3
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: paso 17, imagen 1 de 1
  18. HP Pavilion 15-ab165us Motherboard Replacement: paso 18, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 18, imagen 2 de 2
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: paso 19, imagen 1 de 1
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: paso 20, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 20, imagen 2 de 2
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: paso 21, imagen 1 de 2 HP Pavilion 15-ab165us Motherboard Replacement: paso 21, imagen 2 de 2
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
Conclusión
3 personas más completaron esta guía.
Dillon Hubble
Miembro Desde 10/20/17
653 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G2, Rose Fall 2017 Miembro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
Miembros de 5
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 1,588
