Saltar al contenido principal
HP Pavilion 15-AB153NR Cooling Fan Replacement
Qué necesitas
  1. HP Pavilion 15-AB153NR Cooling Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Cooling Fan Replacement, CD/DVD Drive: paso 4, imagen 1 de 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Cooling Fan Replacement, Bottom Case Cover: paso 7, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 8, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 9, imagen 1 de 1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 10, imagen 1 de 1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 11, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 12, imagen 1 de 3 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 12, imagen 2 de 3 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 12, imagen 3 de 3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 13, imagen 1 de 1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 14, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 14, imagen 2 de 2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
  15. HP Pavilion 15-AB153NR Cooling Fan Replacement, Cooling Fan: paso 15, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement, Cooling Fan: paso 15, imagen 2 de 2
    • Disconnect fan cable from the motherboard.
  16. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 16, imagen 1 de 1
    • Remove both 3mm screws connected to the fan using Phillips #1 screwdriver.
  17. HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 17, imagen 1 de 2 HP Pavilion 15-AB153NR Cooling Fan Replacement: paso 17, imagen 2 de 2
    • Remove the fan from the computer.
Conclusión
2 personas más completaron esta guía.
Nicole Vachon
Miembro Desde 03/21/19
926 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 530
