Saltar al contenido principal
HP Pavilion 15-AB153NR CD/DVD Drive Replacement
Qué necesitas
  1. HP Pavilion 15-AB153NR CD/DVD Drive Replacement, CD/DVD Drive: paso 1, imagen 1 de 1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  2. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  3. HP Pavilion 15-AB153NR CD/DVD Drive Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-AB153NR CD/DVD Drive Replacement: paso 3, imagen 2 de 2
    • Slide the drive out from the right side of the device.
Conclusión
Nicole Vachon
Miembro Desde 03/21/19
926 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 861
