Saltar al contenido principal
HP Pavilion 15-AB153NR Battery Replacement
Qué necesitas
  1. HP Pavilion 15-AB153NR Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Battery Replacement: paso 2, imagen 1 de 2 HP Pavilion 15-AB153NR Battery Replacement: paso 2, imagen 2 de 2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Battery Replacement: paso 3, imagen 1 de 2 HP Pavilion 15-AB153NR Battery Replacement: paso 3, imagen 2 de 2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
Conclusión
Nicole Vachon
Miembro Desde 03/21/19
926 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 519
