Introducción
This guide explains how to replace the memory module (also known as RAM) in an HP Pavilion 14-n018us.
The memory module is a printed circuit board on which memory integrated circuits are mounted. It allows the computer to temporarily store data that needs to be accessed quickly. If your RAM starts going bad, it will result in frequent crashes, slow performance, or errors occurring during startup. If you are experiencing any problems, or are just interested in upgrading your RAM for increased performance, use this guide to replace your RAM.
Qué necesitas
Press the two tabs on the back of the laptop inward to release the battery.
Pull the battery straight out slowly and firmly.
Using a Phillips #00 screwdriver, unscrew the two 6.98 mm captive screws on the black cover on the bottom of the laptop.
Remove the cover.
