Saltar al contenido principal
HP Pavilion 14-cf0014dx RAM Replacement
Qué necesitas
  1. HP Pavilion 14-cf0014dx RAM Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx RAM Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx RAM Replacement, Battery: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx RAM Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx RAM Replacement, RAM: paso 5, imagen 1 de 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: paso 5, imagen 2 de 3 HP Pavilion 14-cf0014dx RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Using your fingers, simultaneously press the two silver clamps away from each other to release the RAM.
    • Each RAM stick will pop up at a 45 degree angle.
    • Remove the RAM from the device.
Conclusión
Sam Cole
Miembro Desde 10/25/21
813 Reputación
7 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 326
