Introducción
Is your device constantly running hot or is overheating? If so, the fan may be faulty and needs to be replaced. Follow the instructions in this guide to remove and replace the fan in the HP Pavilion 14-cf0014dx.
Qué necesitas
Flip the device over so that the backside is facing you.
Remove the rubber feet to expose six screws.
Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
Using the Phillips #0 screwdriver, remove the two screws securing the fan to the motherboard.
