Saltar al contenido principal
HP Pavilion 14-cf0014dx Fan Replacement
Qué necesitas
  1. HP Pavilion 14-cf0014dx Fan Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Fan Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Fan Replacement, Battery: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Fan Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Fan Replacement, Fan: paso 5, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the two screws securing the fan to the motherboard.
  6. HP Pavilion 14-cf0014dx Fan Replacement: paso 6, imagen 1 de 2 HP Pavilion 14-cf0014dx Fan Replacement: paso 6, imagen 2 de 2
    • Carefully lift the fan up and out of the device.
  7. HP Pavilion 14-cf0014dx Fan Replacement: paso 7, imagen 1 de 1
    • Disconnect the fan from the motherboard and fully remove the fan from the device.
Conclusión
Sam Cole
Miembro Desde 10/25/21
813 Reputación
7 Guías creadas
Equipo
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Miembros
7 Guías creadas
Un comentario
Why remove the battery?
Chrillusionist - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 413
