Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion 14-cf0014dx Daughterboard Replacement
Qué necesitas
  1. HP Pavilion 14-cf0014dx Daughterboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Daughterboard Replacement: paso 2, imagen 1 de 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Daughterboard Replacement, Battery: paso 3, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Daughterboard Replacement: paso 4, imagen 1 de 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Daughterboard Replacement, Daughterboard: paso 5, imagen 1 de 1
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Daughterboard Replacement: paso 6, imagen 1 de 2 HP Pavilion 14-cf0014dx Daughterboard Replacement: paso 6, imagen 2 de 2
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Daughterboard Replacement: paso 7, imagen 1 de 1
    • Remove the daughterboard with a pair of tweezers.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 294
