Saltar al contenido principal
HP Pavilion 14-c015dx Chromebook Keyboard Replacement
Qué necesitas
  1. HP Pavilion 14-c015dx Chromebook Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the two 7mm screws with a Phillips Head #1 Screwdriver.
    • These screws may not completely come out of the laptop, so just make sure that you have loosened them all of the way.
  2. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: paso 2, imagen 1 de 2 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: paso 2, imagen 2 de 2
    • Starting from the left side, use the metal spudger to pry off the keyboard.
    • Run the spudger across the edges until all plastic clips are popped up and the keyboard is free from the palm rest assembly.
    • Do not pull the keyboard away from the computer while popping the keyboard off, there is a connector cable in the bottom center of the keyboard that will be disconnected in the next step.
  3. HP Pavilion 14-c015dx Chromebook Keyboard Replacement: paso 3, imagen 1 de 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: paso 3, imagen 2 de 3 HP Pavilion 14-c015dx Chromebook Keyboard Replacement: paso 3, imagen 3 de 3
    • Detach the circuit connector by flipping up the black flap upwards and gently pulling the connector out by pulling up on the blue release tab.
    • Lift the keyboard away from the computer once the connector is detached.
Conclusión
2 personas más completaron esta guía.
Joe Kennedy
Miembro Desde 01/23/17
231 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 22-8, Maness Winter 2017 Miembro de Cal Poly, Team 22-8, Maness Winter 2017
CPSU-MANESS-W17S22G8
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 468
