Saltar al contenido principal
HP Pavilion 14-bk061st Screen Replacement
Qué necesitas
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: paso 1, imagen 1 de 2 HP Pavilion 14-bk061st Screen Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: paso 2, imagen 1 de 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: paso 4, imagen 1 de 2 HP Pavilion 14-bk061st Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: paso 5, imagen 1 de 2 HP Pavilion 14-bk061st Screen Replacement: paso 5, imagen 2 de 2
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: paso 6, imagen 1 de 3 HP Pavilion 14-bk061st Screen Replacement: paso 6, imagen 2 de 3 HP Pavilion 14-bk061st Screen Replacement: paso 6, imagen 3 de 3
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: paso 7, imagen 1 de 2 HP Pavilion 14-bk061st Screen Replacement: paso 7, imagen 2 de 2
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: paso 8, imagen 1 de 3 HP Pavilion 14-bk061st Screen Replacement: paso 8, imagen 2 de 3 HP Pavilion 14-bk061st Screen Replacement: paso 8, imagen 3 de 3
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: paso 9, imagen 1 de 1
    • Remove the screen from the laptop.
Conclusión
Una persona más ha completado esta guía.
Mehrab Daemi
Miembro Desde 01/22/20
596 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 930
