Saltar al contenido principal
HP Pavilion 14-bk061st Motherboard Replacement
Qué necesitas
  1. HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 HP Pavilion 14-bk061st Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Motherboard Replacement: paso 2, imagen 1 de 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Motherboard Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Motherboard Replacement, RAM Card: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Halberd Spudger
    $2.99
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. HP Pavilion 14-bk061st Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the card by pulling it up and away from the slot.
  6. HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: paso 6, imagen 1 de 2 HP Pavilion 14-bk061st Motherboard Replacement, WLAN Card: paso 6, imagen 2 de 2
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  7. HP Pavilion 14-bk061st Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the JIS #1 screw from the WLAN card.
  8. HP Pavilion 14-bk061st Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the card by pulling it away from the slot.
  9. HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: paso 9, imagen 1 de 2 HP Pavilion 14-bk061st Motherboard Replacement, Heat Sink: paso 9, imagen 2 de 2
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  10. HP Pavilion 14-bk061st Motherboard Replacement: paso 10, imagen 1 de 1
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  11. HP Pavilion 14-bk061st Motherboard Replacement, Fan: paso 11, imagen 1 de 1
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  12. HP Pavilion 14-bk061st Motherboard Replacement: paso 12, imagen 1 de 2 HP Pavilion 14-bk061st Motherboard Replacement: paso 12, imagen 2 de 2
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
  13. HP Pavilion 14-bk061st Motherboard Replacement, Motherboard: paso 13, imagen 1 de 1
    • Remove the seven screws from the motherboard using a JIS #1 screwdriver.
  14. HP Pavilion 14-bk061st Motherboard Replacement: paso 14, imagen 1 de 2 HP Pavilion 14-bk061st Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
  15. HP Pavilion 14-bk061st Motherboard Replacement: paso 15, imagen 1 de 1
    • Carefully remove the motherboard from the casing.
Conclusión
3 personas más completaron esta guía.
Mehrab Daemi
Miembro Desde 01/22/20
596 Reputación
4 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 1,038
