Introducción
Don’t feel like you need to purchase a new computer to upgrade to a better system!
This is a step-by-step guide on how to remove and replace a wireless card for the HP Pavilion laptop. Whether you are experiencing hardware failure, issues with connectivity, or just need to upgrade to a better card, this simple guide will help you quickly and safely replace and install a new card to your device.
To begin this project, we recommend that you find a clean, dry, and flat surface to work on. Before you start this project, you will need to power down the device completely.
Note: the images presented show a before and after picture for each individual step to help you keep track of your progress.
Qué necesitas
Insert the plastic opening tool between the keyboard and the palm rest.
Pry upwards until the keyboard section detaches from the laptop.
Repeat this around the edge of the entire keyboard.
Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
Una persona más ha completado esta guía.
