Saltar al contenido principal
HP Pavilion 13-s128nr Back Panel Replacement
Qué necesitas
  1. HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 HP Pavilion 13-s128nr Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Use the iFixit opening tool to take off the rubber caps.
    • Remove the screws using the Phillips #0 screwdriver.
  2. HP Pavilion 13-s128nr Back Panel Replacement: paso 2, imagen 1 de 1
    • Use the Jimmy to pry around the seam of the laptop.
    • Remove the back panel of the laptop.
    • Don't completely remove the back panel as there are ribbon cables that can be easily damaged if removed quickly.
  3. HP Pavilion 13-s128nr Back Panel Replacement: paso 3, imagen 1 de 2 HP Pavilion 13-s128nr Back Panel Replacement: paso 3, imagen 2 de 2
    • Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
    • Pull the cable from the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 782
