Saltar al contenido principal
HP Pavilion 11-n010dx Bottom Case Replacement
Qué necesitas
  1. HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: paso 1, imagen 1 de 2 HP Pavilion 11-n010dx Bottom Case Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
    • Use Phillips #0 to remove four 9mm screws.
    • Use Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Bottom Case Replacement: paso 2, imagen 1 de 3 HP Pavilion 11-n010dx Bottom Case Replacement: paso 2, imagen 2 de 3 HP Pavilion 11-n010dx Bottom Case Replacement: paso 2, imagen 3 de 3
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Bottom Case Replacement: paso 3, imagen 1 de 2 HP Pavilion 11-n010dx Bottom Case Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
Conclusión
Una persona más ha completado esta guía.
Joseph Lintz
Miembro Desde 09/15/16
915 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-5, Blackwell Fall 2016 Miembro de USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,376
